#1 2006-12-28 20:59:26
- Jörgen Lundin
Re : Problems with Turn Flasher
Have someone the solution for my Alliance L -87 Conv. ? 1. My warningflasher works only in one direction, (at right.) 2. My turnflasher have only fixed light. 3. The arrow shine in wrong direction (when I flash to right the arrow shine to left). I need help...!!! /jorgen@wetterreklam.se
#2 2007-01-01 14:17:37
- Vasek
Hi Jorgen,
the hazard lights and turn lights have 2 independent flashers. The hazard flasher is located in the fuse box on passenger side under dashboard. The turn flasher is located close to steering column and it is attached to 2 wires harness. I guess that your problem is not caused by these flasher's units. Please see wiring diagram related to the hazard / turn light. I posted the wiring diagram to Your mail box.
Good luck, Vasek.
#3 2007-01-01 19:57:39
- Jörgen Lundin
The turn fasher dosen´t work´s, have change it. The km instruments and the miles instrument have differnts direction of the arrow, onlt shift the wires. The problems with the warningflasher can be the hazard switch ?
#4 2007-01-04 11:01:44
- Jörgen Lundin
Have someone the hazard switch for sale ? It´s will bee my solution for the problems (I think). / jorgen@wetterreklam.se
#5 2007-01-04 11:58:58
Ask to Nickspartsplus (http://stores.ebay.com/Nickspartsplus), on eBay...
#6 2007-01-04 16:27:34
Hello,
Try this link http://www.lectriclimited.com/mainpage.htm
I hope you find something.
best regards
